Old-Biscuit
Dec 11, 2013Explorer III
midnightsadie wrote:
ok I gotta ask, why are people changing the stats?
Because the analog t-stats over shoot set point by 2-5 degrees
The swap is to a digital t-stat which controls to set point +-1 degree
OP.....
I did the swap without using a mini switch but I wired it to use high fan speed (low fan didn't more enough air for me)
About DIY Maintenance
RV projects you can tackle on your own with a few friendly pointers.4,353 PostsLatest Activity: Mar 10, 2025
