Cumminalong's avatar
Cumminalong
Water tanks
Wanting to extend the water drain outlet so it reaches the edgeof the tank, like to put a tap on it.what can I use? John
  • RickLight wrote:
    Some caution is advised.
    I've been told the drain plug melts as a last ditch safety feature.
    You have been told wrong.
    Barney
    Only if the water goes above 275 degrees. :B
  • Some caution is advised.
  • Extend using pex 90with a shark bite style valve with a hose end, to just behind the bumper, now can fill and drain with out getting under the trailer
  • use a quarter turn valve and some of the idea,s above, plastic pipe easy to work with.
  • Depends on what you have, mine is a 2" pipe with a gate valve coming directly out of the bottom of the fresh water tank.
  • You can unscrew the fitting that goes into the tank and use PVC fittings and pipe to extend and place a valve on the end.
    That is what I did with my tank, extended it to the edge of the trailer frame.
    Assuming it won't spend a lot of time in the direct sun, you can purchase some inexpensive flexible plastic line (not PEX) and a 1/4 turn sink/toilet shut off valve. clamp the line to your current valve and leave it open, controlling the drain from your newly and more conveniently mounted shut off.
    This type of valve was installed by the manufacture on our 13 year-old mini travel trailer we use for overnight hops. They still work fine on the fresh water tank and off the PEX low-point drains.
  • A short pipe with a threaded plug? Is your goal to drain it without water pouring all over the place and instead to the ground?
About DIY Maintenance
