- freewayrandyExplorerThank you both. Yes, I do have an inch lb. torque wrench.
- Old-BiscuitExplorer IIIBuy a NEW ROOF Gasket
Disconnect A/C power and control wiring (120V AC and 12V DC)
remove hold-down bolt nuts (4 total)
Then up on roof and lift A/C Unit up/out of rood top hole
Clean up roof surface
Clean up bottom pan on A/C unit where gasket sits
Install new gasket and set A/C Unit down into hole
Install hold down bolts....then nuts
Tighten nuts 'X' pattern until 'SNUG' (if you have an 'INCH' torque wrench --- 40 Inch/Lbs) the new gasket is 1" thick and should be compressed to 1/2"
Do NOT over-tighten
You will crush gasket and deform roof line------SNUG only - ksg5000ExplorerI replaced the seal in my Coleman with the assistance of my wife.
As I recall - disconnect from shore power - remove the inside shroud - disconnect the electrical harass - remove a couple of bolts which hold the AC to the rig. Then head up top.
On top you should bring something to sit the AC your about to remove (avoid damaging the roof) I used some plywood. Remove the exterior shroud - lift up the unit (heavy but one man job) and place it on the plywood or whatever. Remove the old gasket and clean the area up - attach the new gasket (should have it's own sticky) and then replace the AC - your wife/partner inside the rig can help you guide the placement. Once in place replace the bolts you removed (not too tight)reattach the electric harass - replace the interior/exterior shrouds. Turn on the power and test the air conditioner - if it works - then turn everything off, grab a hose and see if it's water tight - it not then you may need to tighten the bolts more.
Might be some YouTube's on the subject.
Hope this helps.
About Fifth Wheel Group
19,006 PostsLatest Activity: Feb 16, 2025
