jfskeet's avatar
jfskeet
Antenna leak
Was out over weekend and had some heavy rains. had a steady drip from the crank on bat wing antenna handle. Tried lowering and rotating it and made no difference. After rain stopped, climbed on roof an took a look and couldn't find anything.
Anyone know if there's seal under flange or should I look for leak else where ?
Thanks in advance
JF
  • VoodooMedicineMan wrote:
    No No NO not caulk silicone spray lubricant
    He means caulking the cable entryway under the boot (silicone caulk can be used here). The silicone spray is for the O-ring.
  • You will have to work from the inside out to get to the o-ring and the spring washer. You have to remove the crank then you will see a nut around the shaft about 3 or 4in maybe more up in the roof. I made a tool like this
    http://www.swidenonline.com/s-271-winegard-antenna-parts.aspx
    out of 1/2" PVC white pipe screwed a 1/2" bolt in one end and used a bench grinder on the other end to fit a socket but I can't remember the size of the socket, something like a 1" Don't get the nut to tight when going back together or you will not be able to turn it left or right when up.
    Hope this helps
    JR
  • Thanks everyone, will get caulk and take a o ring kit with me this weekend and see what I find
    jfskeet
  • ScottG wrote:
    On the roof, pull up the little rubber boot that covers the cable connection between the base and the antenna and fill it with silicone. That a spot that always just waiting to leak.
    2X
  • trustymopars wrote:
    Another problem spot is the o-ring on the shaft. It's best to lube it a couple of times a year with silicone spray. If it's not been lubed in a few years, it may be dried out or broken. They do make a repair kit for it, and is not too bad to fix. I repaired my SIL's, due to lack of lubrication.
    Yes, the owner's manual states to lubricate the o-ring.
  • Another problem spot is the o-ring on the shaft. It's best to lube it a couple of times a year with silicone spray. If it's not been lubed in a few years, it may be dried out or broken. They do make a repair kit for it, and is not too bad to fix. I repaired my SIL's, due to lack of lubrication.
  • On the roof, pull up the little rubber boot that covers the cable connection between the base and the antenna and fill it with silicone. That a spot that always just waiting to leak.
