nayther
Nov 01, 2016Explorer
start by checking for a good ground, if the ground was compromised that could lead to excessive amps drawing from the battery. If that checks then start from the battery and work your way to the 12v common bus at the fuse panel while maintaining the good ground at the battery. At least that's the method I'd go to.
About Fifth Wheel Group
19,006 PostsLatest Activity: Jan 13, 2025
