BigDogF250
Nov 01, 2016Explorer
Nayther, you made me almost laugh coffee out my nose. It's a WW built in 2005, the "common bus" is wire nuts! One more thing I found wrapped in electrical tape this weekend that needs to be replaced.
At this point I am starting with running proper grounds and new positive from the battery to a real common bus, replacing the funky 8 fuse and rigged 3 fuse add on they used instead of a proper fuse panel and seeing where that gets me. Hopefully it's just corrosion or gremlins in one of those systems.
About Fifth Wheel Group
19,008 PostsLatest Activity: Mar 07, 2025
