SpurHntr
Oct 08, 2013Explorer
Converter trips receptacle gfci help needed...
Rig in sig below.
Converter is a Parallax 7355
Using a 15 to 30 A adapter from a 25 ft extension cord to the campers 30 amp cord:
Plugged in to a 15A gfci receptacle with non gfci breaker.
(Converter functions normally and does not trip when plugged in to 15A NON gfci receptacle NON gfci breaker at home using same extension cord/adapter)
Turning off ALL other breakers except the main on RVs panel and turning ONLY converter breaker on still results in receptacle gfci tripping.
If leave converter breaker off EVERYTHING else works fine(Ac, micro, water heater, fridge)and receptacle does not trip.
Obviously the issue is my 12V power, which I won't have long without a converter.
I heavily rely on lights and the water pump, as do most of us but generally use LP for fridge and hot water when using only 15A receptacles and don't use the AC.
Batteries are good. Converter output good. All wires/connections solid.
Thoughts?
(Sorta kinda fear just putting in a non gfci receptacle fearing the obvious)
But, can't say I can even recall the last time I plugged my Moho or my prior fiver into a gfci receptacle, if ever, so am I worrying needlessly?
Any help appreciated.
Thoughts?
