โSep-10-2017 05:02 AM
โSep-11-2017 03:40 AM
Tom_M wrote:flyfishing48 wrote:I checked the specs on three weBoost units. Two stated 50 ohm impedance, one stated 75/50 ohms. Since your device came with RG-6 coax, you will be able to use the coax installed in your RV. Check the specs for your model to make sure.
My weboost came with a rg6 cable from the outside antenna to the booster, isn't that a 75 ohm cable? The label just st says says rg6
โSep-10-2017 10:03 PM
โSep-10-2017 08:18 PM
โSep-10-2017 06:10 PM
Me Again wrote:
Or one of these with the Dicor.
http://www.ebay.com/itm/like/132192528892?chn=ps&dispItem=1
โSep-10-2017 02:09 PM
flyfishing48 wrote:The most common coax used for TV is RG-6 and RG-59. RG-59 isn't used much anymore. Both are 75 ohm coax.
My weboost came with a rg5 cable from
The outside antenna to the booster isn't that a 75 ohm cable? The label just st says says rg6
โSep-10-2017 11:22 AM
โSep-10-2017 10:47 AM
โSep-10-2017 10:11 AM
โSep-10-2017 10:07 AM
โSep-10-2017 07:13 AM
โSep-10-2017 06:12 AM
โSep-10-2017 05:23 AM
