humblerb's avatar
humblerb
Fifth Wheel Hitch issue - How to correct?
Long story, but I'll try to keep it as short as I can.
3 years ago, bought a B&M Patriot slider for my RAM 2500.
Had the dealer install rails. My first experience, so I didn't know any better. Dealer had trouble getting the base to fit in the rails. After an hour of working on it, they finally got it in.
Got home and discovered they installed the base backward.
I removed the pins, turned it around and went to reinstall it.
Took me about an hour of working with it to finally get the base in to the slots.
I could get any 3 tabs in, but the 4th took a lot of working around with a 75 pound hitch to get it in.
Recently bought a new RAM 3500 with pucks.
I bought a Reese adapter to use the pucks with the same hitch.
Now the four tabs slip in, but when I go to put the pins in, I can get the two toward the tailgate with no problem.
I can get either one of the two near the cab in, but the other does not go straight in - similar to the rail issue before.
If I use a hammer, I can beat the pins in. But, with the new truck, I am trying to make this process better going forward.
Measuring the pin holes on the base center-to-center, the holes are right at 28-7/8". They should be 29".
If I were to ream out the hole on one side (1/8") or both holes (1/16" each side) it should allow the pins to slide in.
This is half inch steel and is very tough.
Anyone have any thoughts on how to accomplish the ream?
I'm fairly handy, but I do not have any tools that would accomplish this.
Thanks for any help.
