DRM796 wrote:
Starting to look at replacing our truck and I have a question. How can you calculate how much pin weight a truck can handle prior to purchasing ?
We are looking at moving up to a one ton and was interested in the difference between srw and drw trucks.
Check the door sticker on any =specific= truck you're interested in and see what it says. Normally, the sticker will show net payload with 1 150 lb driver and full fuel, but some may not use full fuel. From there, start deducting for additional passengers, hitch and "stuff" you might carry in the truck. What's left over, is the net payload for that truck. If that number works for a FW you're looking for, then you're good to go.
Something else that a lot of RV mfrs are now doing, Jayco in particular, is they are putting a weight sticker on their units that is specific to =that= unit. This means that one with solid counter tops should show more cargo capacity than one with standard counters, or standard glass vs dual pane. The ones on Jaycos show the net CCC with full propane and one battery, then also give the specs for a full tank of fresh water.
Lyle
