Leveling my fifth wheel
Ljm352
I have recently pulled into a new park and leveled my unit. A neighbor said I did it wrong and was going to bend my frame. In the front the stabilizer jacks are on a couple boards but they aren't both pinned in the same hole ex. One is holding one side taller than the other. On the back I have a cinder block with some board on it under the skid plate to hold it level. (Yes the book says it is okay to use the skid plates as a place for jacks) does this sound like it will bend my frame?
Thank you!!!
15 REPLIES 15
eHoefler
If you are leveling with the stabilizer jacks, yes. You need to level side - side with boards/blocks under the tires. Then level front to rear with the jack/landing gear. Then you lower the stabilizer jacks just enough to apply pressure to keep the bounce down, not to lift the trailer.
2021 Ram Limited, 3500, Crew Cab, 1075FTPD of Torque!, Max Tow, Long bed, 4 x 4, Dually,
2006 40' Landmark Mt. Rushmore
