RobWNY's avatar
RobWNY
Not using the Washer and Dryer Hookups
During the PDI for my new 5th wheel, I explained to the dealer that I wouldn't be using the washer and dryer hookups that are located in the bedroom closet. He wasn't clear when asked about what to do when Winterizing and De-Winterizing those connections. He said just use a bucket or something when De-winterizing this Spring and after that, not to worry about the washer/dryer connections and lines again. I specifically asked about running Anti-freeze through the lines like you do for the rest of the camper when winterizing in the fall and he said it wasn't necessary. That just doesn't seem right to me. The Manufacturer put anti-freeze in those lines before shipping the camper to the dealer so shouldn't those connections be treated as any other faucet would be going forward? What would be the best method to use so there's not water/anti-Freeze all over my closet area? I was thinking about attaching a hose to both valves and have them drain into a sink. Is there another method used that might be a better solution or was my dealer correct when he said after De-Winterizing, not to worry about those connections again?
