- n3eqfExplorer
ArchHoagland wrote:
Two people have mentioned seeing a picture.
I don't see any pictures, just his statement.
What am I missing?
Hit the "view profile" button on his entry to see the photo. - ArchHoaglandExplorerTwo people have mentioned seeing a picture.
What am I missing? - YC_1NomadLooks like a Monaco??
If you are having to reset the switch near the entry then your cutoff solenoid may be failing.
The solenoid is most likely below the driver in the outside compartment and inside a large black plastic box. Bottom left corner. It is a latching relay and a common problem. Replace the solenoid or just stack all the wires from one side of the large connections to the other for either a temporary or permanent fix. Many just bypass it and forget it.
check these threads - ArchHoaglandExplorerYear make and model of RV will help us.
- Which switch are we talking?
The battery disconnect? Look at failing control switch.
Circuit breaker? What amperage rating? You could be having some device failing like a light fixture ballasts.
Nice photo on Icefields Highway! - ksg5000Explorer IIAre you referring to a std 12 volt auto reset breaker? Some come with button to push and some don't. If so - I would start with replacing the breaker (inexpensive) which would at least rule out the basics.
- jdc1Explorer IIYou'll have to retrace your steps.
38,763 PostsLatest Activity: Mar 21, 2016
