faucet1
Oct 04, 2018Explorer
2002 Diplomat 12 Volt Circuit Board Removal/Repair
Anyone tried to remove the large 12 Volt Circuit Board on the older Monaco units? The Board(15x10 inches) is mounted inside a plastic box, I suppose for protection from the elements, even though it is inside a compartment below the Drivers side window. In any event, I need to replace the melted Ignition Socket which is soldered into the Circuit Board. If you have removed this Board...how did you get it out of the plastic box with the long mounting/retaining bolts. Especially with the large wiring cable running through/across the box in front of the board. I see no connectors to take the wire apart? Anyone tackled this?
