CG_Dawson
Jan 28, 2015Explorer
Are you sure the battery is down? I went through this type scenario to the tune of $525.00 only to find that the distribution relay, located on the radiator frame under the right front fender, contacts were dirty to the point of not making contact. This relay is powered directly from the battery and when energized distributes power to all of the critical areas of the chassis. Dirty contacts and you are dead in the water.
38,708 PostsLatest Activity: Mar 05, 2025
