Chainwright wrote:
Executive wrote:
Chainwright wrote:
So just to clarify, the rhino covering that is being discussed here is not the black rhino skin that you see in the bed of trucks, this rhino finishing/coating has the same paint job/artistic pattern-designs as the original design (they just use/create a stencil from your design) of the rig. Once the paint job over that rhino skin is done, you don't even notice it unless you're 2-3 feet away from it.
Nope. The rhino covering is the same as the black rhino skin you see in the back of pickups. They can add some coloring to it but it works best if it's a dark color. Good stuff, but not my cup of tea...Dennis
I'm pretty sure the OP (sarhvac1) is talking about the Rhino skin I described. Had I not seen it with my own eyes I'd even give you the benefit of the doubt, but not in this case. sorry. I even got some literature, when I find it I'll post it.
So the stuff I was talking about, and I think the OP meant the same product, is called Vortex coating. Actually if you have 10-15 mins you can read all about it at
http://rvwanderlust.com/how-to-protect-the-front-of-your-rv
