WesternHorizon's avatar
Feb 03, 2015
'95 E350 Class C: ABS module failed, not available
Shortly after I bought my '95 Fleetwood Tioga Montara on a E-350 chassis last year the ABS light came on and stayed on.
I took it to an independent and they spent a lot of time trying to find the OBD1.0 connector without success.
So I took it in to the Ford dealer: ABS computer module has failed.
P/N: F3UZ2C018B (corrected: Dual Rear Wheels)
Problem: This part is out of production / stock.
Concern of mechanic: Even if I can find one, he has seen a used one not synch up with rest of the brake system.
Anyone have any related experiences or suggestions? Many thanks.
  • j-d's avatar
    j-d
    This recent thread discusses that ABS Valve, even though the subject is Master Cylinder Diameter.
    It also includes this link about testing one.
    I didn't scour the thread for another link but I believe there was one more in there someplace. Subject RV was a 1993, and I don't know if the chassis was 1993, could have been earlier.
    Always work from the CHASSIS year (dashboard VIN and Ford/Chevy door jamb label) and NOT the year Fleetwood or whomever called your RV.
    ABS diagnostics, at least on these Fords was NOT part of the OBD-1 suite. Even finding the connector, which I believe is underhood near the brake booster, would not read out the ABS Codes. There was a gyration to get the ABS Light to blink them out. I think something in the above links steers you to that process.
    • Thanks for your reply. I don't think I saw it back in the day. Last year in AZ I met a guy who had gotten a rebuilt assembly. My notes from 2015 are not clear, but this MIGHT be what I need:
      Cardone ABS Hydraulic Assembly
      Part # 12-2061$143.99 + $42.00 Refundable Core
      Exact fit for your 1995 Ford E-350 Econoline
      Reman ABS Hydraulic Assembly; 2-Wheel ABS
      If my project list ever gets shorter, maybe I will revisit this.
  • Had same thing on my '94 E350. No part to be found. I took a black sharpie to the dash.
    I also documented the whole thing including the written report that as it was, there was indication of ABS failure. I included that when I sold it.
    Gary Haupt
  • Had a similar problem with my 2005 Jeep. They found a used unit, fortunately. but what a drag.
  • Good point. I did find a new unit for $50, so I'm going to gamble on the safe side and get the ABS fixed.
  • Same thing happened to my '94. I just elected to drive it as-is. People got by without ABS for decades. The brakes function just fine, other than the lack of ABS.
