ROYBUCK
Mar 16, 2015Explorer
ABS Light
Tis a little information if you have a problem with your ABS light not going off. The code did not pin point this problem, This was found with a Monaco tech helping the tech on the MH, all sensors worked, the fault code that read out was not the problem. There is a ABS Blink light circuit Board in the compartment under the driver that was the problem, so if you have a problem and can't find it check this Circuit Board, the Monaco tech found it not the tech on the MH. Now listen to this. $855.54 and not a part used, I need to order the part. Just labor.   What can you say. A couple Cool one will make me forget it until next time. This was a Intermittent problem its working now but for how long, then I will pay for a circuit board and labor again.  Roy
