RRTom's avatar
RRTom
Battery questions
I just had the house batteries replaced with AGM's. I checked the built in "battery control" and voltage was reading 8.85. This was one week after install. I started the generator to exercise it, the A/C and charge the batteries. The gen ran very rough for about a minute and half, and then stopped. I will let the dealer sort the gen problem out since it's still under warranty.
I plugged in the 50 amp this morning and immediately checked the "battery control" and got a reading of 13.3. I left it alone for a while and it stayed right in that range. I have now unplugged the 50 amp and the voltage dipped to 12.9, did the battery disconnect, and I will check again in an hour. I have been told that leaving the 50 amp plugged in while parked next to the house will damage my batteries.
Also, when i do the battery disconnect, and then reconnect, the radio comes on by itself. ???
I am "electrical system illiterate" and would appreciate any possible explanations for this.
