- jhilleyExplorer
crasster wrote:
I always replace custom RV stuff with stuff from Home Depot. Every time you go custom it will be $$$$ Now the place may be reasonable for replacement, but if you smell a ripoff for plastic covers, I'd go HD or Lowes.
Not much in 12 volt lighting at Lowes or other big box stores. When I look to replace things in an RV, I look at marine equivalents, usually much better quality. The Thin-lite fixtures are good lights, especially so if the fluorescent tubes are replaced with LED tubes or strips. - crassterExplorer III always replace custom RV stuff with stuff from Home Depot. Every time you go custom it will be $$$$ Now the place may be reasonable for replacement, but if you smell a ripoff for plastic covers, I'd go HD or Lowes.
- jhilleyExplorerThey are available from John Drake
- xctravelerExplorerIt may be cheaper to just replace the fixtures. Last i looked they were less than $10. Change them for LED fixtures in the same form factor and they will cost more, but you can forget about servicing them and your batteries will love you.
About Motorhome Group
38,707 PostsLatest Activity: Feb 18, 2025
