Wandering_Storm's avatar
Apr 04, 2015
CHF
Pardon my ignorance but...What the heck is the cheap handling fix for a 2015 Fleetwood Storm. Thanks
  • The above photo pretty much sums it up. Just move the links from the outer most hose to the inner most hole and enjoy the improved ride.
    For pages and pages of descriptions and explanations, just click here.
  • Look at the anti sway underneath. The sway bars have holes further back in addition to holes that are used. Some owners have moved the bolts to the other holes in theory making them working better and less MH sway. I did mine front and back. In the back it helped some. In the front the angle was wrong. I removed the front when I added a heavy duty anti sway bar. In the rear I also added a heavy duty anti sway bar but left the factory anti sway in holes shortening the bar. The term CHF is slang for "cheap handling fix". On the Ford chassis you pretty much need anti sway bars front and rear,
