Goldencrazy
May 05, 2015Explorer
city water back flow valve leak
A friend has a steady drip from his city water inlet when his pump is engaged with water in the fresh tank. Pump recycles about every 15 minutes. No leaks when hooked to city water. Only when working off fresh water tank. The plastic back flow seems a bit rough when pushed in. Do these wear out? Can the check valve be replaced or does the entire inlet need to be replaced?
