ricelake922's avatar
ricelake922
Cluster of fuses have been rerouted......help !!!!
Hello. I was using a test light on fuses that are located outside below the driver's seat. The cluster of fuses on the left side of the box work fine according to the test light. The cluster of fuses on the right side (18 accesories in total) do not register with the test light at all. I tested this non registering cluster with the engine on and off. None of the fuse wires in the fuse box have been disturbed or changed. I pulled a few fuses and tested behind the fuse in the box and nothing. I then tried some of the accessories that are associated with these fuses and they all work fine. I spoke with my mechanic and he says that before I purchased the RV someone must have taken that cluster and rerouted it to another power source. This could be a big big problem as one of the accessories in this cluster works the back brake lights. Anyone have any suggestions...ideas...solutions to what could be a big problem. Thank you in advance.
