wanderinghome's avatar
Apr 30, 2013
dash a/c 1998 fleetwood discovery
My dash a/c is not working. Every thing is fine except no current to activation side of relay. Cannot locate high/low pressure switch. There do not seem to be any along the lines anywhere. is this system controlled some other way and where should a person start looking? does anyone have an electrical schematic ? both freightliner & fleetwood only have production drawings.
  • by any chance do you have a Denso air condition system?? If so download this manual. You will find the high/low switch located inside the cooling box or A coil.
    http://www.densoheavyduty.com/pdf/HVAC_Service_Manual_for_RV.pdf
