Do you think anything will freeze?
StephJohn2010
Ok. So, I'm back home in South Dakota, but my motorhome is in an outdoor storage facility near Fort Collins, Colorado. I placed it there just a few days ago and now I see in the weather forecast that there is a freak cold snap coming into Colorado Wednesday. I really really don't want to travel in the car 350 miles, rent two nights at a campground (so I can keep the motorhome warmer during the cold snap), and then drive the 350 miles back home. Do I need to worry about things freezing up if the temperature is going to get down to 23 degrees overnight? The daytime temp shows it to be about 38 degrees for a high. I didn't winterize because, well the hard freeze stuff is not supposed to even happen this time of year in that area. I drained the water heater, grey and black tanks, and I have 'low point' hot and cold drains which I also drained. Really the only part that I'm really worried about is the tiny fresh water line that goes to my residential refrigerator. That probably has some water in the line. What would you do...just cross my fingers and hope or drive down and try to keep the rig warm during the overnight cold snap by staying in it and running the propane furnace?
John & Steph
2012 Fleetwood Discovery 40x (35,000 miles)
380 HP Cummins with an Allison Transmission - Freightliner Chassis
2015 Jeep Cherokee Limited Active Drive II
14 REPLIES 14
StephJohn2010
BarbaraOK wrote:
It snowed on my birthday (May 22nd) one year in Fort Collins when we lived there in the 70s. What made you think the cold weather was over?
Why are you storing your rig so far away?
Barb
I didn't figure on low twenties. It is a cut off low pressure system. Heck, South Dakota will be warmer than the plains of Northern Colorado on Wednesday. I stored in Fort Collins because we are staying there in June and July, just wanted to save the gas and not really any good place to store back home.
John & Steph
StephJohn2010
JTHarley wrote:
I know you may not want to hear this BUT it was just that little line that went to my fridge for the icemaker that DID break.....I even blew out the lines but forgot to do the ice maker and then we got a hard freeze for 2 days.
That's a bummer. What did that repair cost?
John & Steph
DeWat
I think this would be a very iffy situation, and would be scared to take the risk. While the water may have been drained via low point drains, unless you actually blew the water out of the system, there's still going to be water in some of the lines. If the faucets and/or drains have not been left open and any water does freeze, where is the air in the lines going to go as the water expands as it turns to ice? Not saying what to do, but it would sure scare me.
Dewey & Sharon
Southern Maryland suburbs of DC
2014 Tiffin Phaeton 40QBH
Jayco-noslide
Anything around 27 or 28 or below for several hours, I would worry. Whether I would worry enough to travel that far I doubt. A 700 mile round trip will cost you several hundred dollars(total cost, not just gas) which might repair any minor damage from freezing.
Jayco-noslide
Ozlander
Toilet valve and water pump will crack.
Ozlander
06 Yukon XL
2001 Trail-Lite 7253
crasster
It is a risk, but I think that you'll be okay.
4 whopping cylinders on Toyota RV's. Talk about great getting good MPG. Also I have a very light foot on the pedal. I followed some MPG advice on Livingpress.com and I now get 22 MPG! Not bad for a home on wheels.
fourmat
700 mile round trip is a long way but you are gambling. Better be real careful and do a good inspect when you put the water back to her.
2009 Challenger
I_am_still_wayn
I totally disagree with the previous posters. First, remember water freezes at 32! You will have freezing on board your RV. A daytime high of only 38 will not hold the temperature inside and under the floor (where the water lines are) above freezing when the temps reach 23! I bet you experience temps below freezing in the RV long enough to risk freezing water pipes.
rgatijnet1
I wouldn't worry about it but I would be sure to put that on my list of things to closely check the next time you go to use your coach.
JTHarley
Jim , MJ & Spirit of Sambuca Bear
2015 Dynamax DQ320XL
Jeep Sahara Toad
Goldencrazy
I wouldn't worry. A little water in lines won't hurt anything as it has room to expand.
BarbaraOK
Barb
Barb & Dave O'Keeffe - full-timing since 2006
Figment II
(2002 Alpine 36 MDDS) 🙂
2018 Ford C-Max HYBRID
[purple]FMCA - F337834, SKP #90761[/purple]
Our Blog
All58Parks
Based on your description of what you did, if I were in your position (and I have been), I'd risk it but allow some time when you're taking it out next to fully check it over.
2014 Wildcat Maxx 26bhs
2014 Ford F-150 Lariat Supercrew
Jack_Diane_Free
If daytime temps are 38 you should be ok.
