- nomadnazExplorer
since posts are old I'm guessing no one reads or reply's here anymore
- pianotunaNomad III
yes this board is more or less dead. It is quite sad really.
- StimExplorerYou don't say why you want to drain. ??
When winterizing you need to find all drain points so lines don't freeze. - NewbiecampersExplorerOn our Coachmen Freelander 21QB the fresh water tank drain line is under the drawer that is under the oven, along with the low-point drain lines. You'll need to open the drawer and look behind it on the floor.
You can't see them from under the coach 'cause the propane tank blocks the view of the three. They drain out on top of the propane tank.- nomadnazExplorer
Exactly, who does that? Have to remove drawer to get to and it does drain on top of propane tank. Who does that ?
- lhenry8113ExplorerWe have a Forest River Forester Class C. Coachman is a division of Forest River. Our water tank drain lever is in back storage compartment, drivers side. Front inside wall of compartment has round removable disk{unscrew) cover. In back of that is a small silver color lever-turn that water drains out. Good Luck, Lars
- jamesuExplorerUnderneath I would be looking for either of these: (1) a small spigot next to a fairly small protruding tube that allows the water to drain...turn it counter-clockwise to open, or (2) a 3rd pull-handle underneath similar to your black and gray pull handles. If your rig has #1 the water drains in a steady flow so get yourself a cup of coffee or do some chores while you wait. If it’s a #2 the water will come out in a gush. Either way it’s just water so I do this operation at the end of the season in the driveway when I am winterizing.
Welcome to the RV.net forum, KennyBoy. - bobndotExplorer IIFind the location of your water tank. It might be under the bed , they are usually supported by the floor of the MH to support its weight. Follow the line down to a low point and see where it goes where you would have access to it.
Sometimes the valve is located at the tank and you can turn it from the inside.
If your fridge has a panel below it, try to remove 4 screws holding it in place and see what's behind that panel . I had low point drains there and they drained my tank too.
Sometimes the valve is behind a removable access panel inside one of the exterior baggage compartments .
Try the compartment closest to the water tank first.
** On some units that valve is also a low point drain for the H/C lines as well. If you see 'low point drains' and it takes forever to drain those lines, then you are draining the freshwater tank as well.
Look below the gravity water fill twist-off cap if you have one (that's a common area as well) - midnightsadieExplorer III,d look under the tank for a drain valve.
