sjthaxter's avatar
sjthaxter
Ford F53 emergency brake fluid
Please help. New to me motorhome 97/98 Pursuit on a Ford F53 chassis. I have searched several forums and the documents we got with purchase. I can not locate the fluid reservoir for the emergency brake. I see what looks like a reservoir, but all the bolts around it are attaching hardware. Is this on the right or left side of the coach? Ahead of the brake enclosure or behind? On top or side?
This is making me crazy, I suspect it isn't a problem, but would really like to know how to get to it for future maintenance.
Thanks in advance.
Regards,
John
  • Those reservoirs were overfilled at the factory, so unless it had leaked, you may find that it runs out a bit when you remove the fill plug. This is normal, nothing to worry about.
  • If you look at the e-brake unit from the drivers side just above where the brake cable runs to the unit you should be able to see a male pipe plug. This is what your looking for take it out and trans fluid should be level with the bottom of the plug hole. It only takes a few oz. I put some trans fluid in a pump oil can with a long flexible spout and fill till trans fluid starts to run out then put the plug back in and hit the area with brake clean.
    Some times it helps to put your head up by the bottom of the floor and the back of your head on the inside of the frame rail on the drivers side.
  • The e-brake is on the driveshaft attached to the back of the transmission and the fill plug is Item 16 seen here on the 5th post:
    http://www.irv2.com/forums/f23/emergency-brake-shoe-repair-f53-78154.html
    Lou
    05 Travel Supreme Envoy
  • Good Reason, There's not a separate one.
    On that model the emergency/parking break is cable operated
