Ford V10
haste_maker
Has anyone had to replace the throttle body on a V10? And if so what year was your unit & the amount of miles..
Retried Teamster
2007 Allergo
14 REPLIES 14
pianotuna
Nomad III
Nomad III
haste maker,
Thanks for letting us know.
Regards, Don
haste_maker
Update on my throttle body problem, replaced it & everything runs like or better than before, I seem to have more power now & I know I am getting better gas mileage...thanks for all the reply's.
Retried Teamster
2007 Allergo
haste_maker
Gjac wrote:
haste maker wrote:
dodge guy wrote:
What year is your coach? Drive by wire started around 06?
2007 year
That means your chassis is probably a 2006. Is there an engine code that shows up like a PO505, PO506 or another code that indicates an idle issue? You say it only idles, if you step on the gas will it stall?
No it didn't stall when I stepped on the gas..don't know about those codes, I do know it does have the wired throttle body.
Retried Teamster
2007 Allergo
Gjac
haste maker wrote:
2007 year
haste_maker
2007 year
Retried Teamster
2007 Allergo
dodge_guy
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
theoldwizard1
Matt_Colie wrote:
Haste,
Look at things carefully, I would suspect the throttle position sensor. It is on the side of the throttle body and they have been know to fail.
It has been a LONG TIME since I looked at one, but IIRC, on electronic throttle bodies there are 2 sensors (or a dual sensor). One for the microprocessor that runs the throttle motor and one for the ECM.
theoldwizard1
Gjac wrote:
There is also an IAC valve (air idle control valve) that sometimes sticks that can be cleaned also.
Nope !
IAC went away when electronic throttle control came in. Also eliminated the cruise control actuator. Eliminating those 2 components, plus better fuel economy and emission controls justified the cost.
Gjac
haste maker wrote:
Gjac wrote:
What makes you believe it needs to be replaced?
It will only idle & the code reads throttle body stuck.
I would check the senor first as Matt suggested and then spray some throttle body cleaner like CRC and see if that fixes the problem. There is also an IAC valve (air idle control valve) that sometimes sticks that can be cleaned also.
Matt_Colie
Haste,
Matt - the refugee from Detroit engine labs
Matt & Mary Colie
A sailor, his bride and their black dogs (one dear dog is waiting for us at the bridge) going to see some dry places that have Geocaches in a coach made the year we married.
haste_maker
Retried Teamster
2007 Allergo
Gjac
MountainAir05
1999 and the only issue was Coil on plugs and a mouse family.
pianotuna
Nomad III
Nomad III
130 thousand miles--no problems with throttle body. One mass flow air sensor. Unit is a 2004.
Regards, Don
