BillHoughton
Jul 18, 2016Explorer II
Fresh water fill part, and the filling ritual
The part question: I've got an Itasca Navion RV on which the fresh water fill point is leaking, both when I put water in and, on a recent trip, at all times (indicating that the check valve is no longer 100%). The leak's not big, but it's enough to warrant fixing. The factory part is $60, and has a little plastic female tapered bushing that mates with a plastic tapered fitting. I'm taking it to a local RV parts place, but is this likely to be unique to Winnebago?
The filling ritual: I both filter and chlorinate our incoming fresh water when filling the tank. At the moment, I've got a non-replaceable filter, and am using a Culligan RV filter housing (no filter in it), in which I put a little chlorine for the chlorination. That, plus the hoses to reach the spigot, pressure regulator and a shutoff (the spigot at home is 50 feet from the RV's parking place, all using regular garden hose fittings - it adds up to a lot of connecting to put water in.
I'm looking at how to simplify it. Step one seems to be to get rid of the non-replaceable filter and put a filter in the Culligan unit, and then put the splash of chlorine in too. Any reason why not?
I'm also wondering whether it would work to use brass quick-release couplings, so I could snap together the various bits quickly.
