Oct-06-2016 12:22 PM
Oct-07-2016 11:19 AM
Oct-07-2016 11:12 AM
Jayco-noslide wrote:
Personally I don't think it would be worth trading to a diesel because of the issues.
Oct-07-2016 08:49 AM
Bumpyroad wrote:'tiredTeacher wrote:J-Rooster wrote:
I own a gas coach and I never have had a problem getting in or out of a gas station that cars go into.
Then by all means, come drive I-95 from Virginia to Florida. Better still, try the Sheetz at Fort Chiswell on I-81.
I have used that one several times. as I recall, the RV pump is sort of situated on the right side and does take a little wiggling around to use it.
bumpy
Oct-07-2016 08:30 AM
Oct-07-2016 08:16 AM
Bumpyroad wrote:
I use a copy of The Next Exit which highlights the RV friendly stops in red. also when passing exits we try to see if the stations there appear to be usable and note them down in the book.
bumpy
Oct-07-2016 08:11 AM
Oct-07-2016 07:49 AM
...So my original question is answered. Everyone driving a gasser has to deal with the same problems I am.
Oct-07-2016 07:15 AM
pigman1 wrote:
I don't want to be a troll about this, but if you're having trouble getting in and out of a Flying J you really need to seriously upgrade your RV driving skills.
Oct-07-2016 07:04 AM
Oct-07-2016 07:00 AM
rgatijnet1 wrote:
It's really pretty simple. If you are below 1/2 tank or so, and you see a station with easy access, you stop. When you wait until the tank is near empty and you have to stop, then your choices will be limited.
Oct-07-2016 06:10 AM
Two Jayhawks wrote:
To the OP....I completely agree with you as I had similar experiences with my first coach years ago. My 95 Bounder was 36' but diesel and that made it challenging. This is because it excluded me from truck stops as it only had the small fuel fill. So I mostly used mom & pop stations that typically only had a single diesel fuel pump. Looking back I should have had it modified. Regardless we are 43' plus now and use truck stops exclusively and it is much easier.
Oct-07-2016 06:06 AM
Oct-07-2016 05:09 AM
malexander wrote:
You just have to plan ahead. Not saying pre-trip plan. Just look over the station you're about to, or want to pull into and make sure you can get out BEFORE you get into a situation you can't get out of.
Oct-06-2016 07:44 PM
