Mar-26-2015 03:35 PM
Mar-27-2015 01:44 PM
Mar-27-2015 01:41 PM
Stutch wrote:
Hi all!
I'm trying to use Garmin basecamp. I honestly have to say I have never seen a application this poorly designed in my life. Intuitive, it is NOT!
A simple example.... There is a function on the menu bar labeled "Trip Planner." Nowhere in Help or instructions explain what this is or how to use it. If you search the index or subjects it comes up blank.
I spent most of the day trying to put in a round trip route with 5 stops and have failed. Basically very frustrated since I was hoping I could use this to plan and then export to the RV760LMT.
Have you had better success with Basecamp or can recommend any other software that will export to a Garmin GPS?
Thanks
Mar-27-2015 11:13 AM
RicJones wrote:
2x on it sucking. You might do a google search and try to find an old copy of Mapsource from Garmin, much easier to use. The only issue may be maps.
I use both and like others said found BaseCamp difficult to work with, with too many work arounds for me.
Mar-27-2015 10:33 AM
Mar-27-2015 10:15 AM
Mar-27-2015 09:22 AM
Mar-26-2015 05:47 PM
Mar-26-2015 05:44 PM
Mar-26-2015 05:41 PM
Mar-26-2015 05:04 PM
Mar-26-2015 04:47 PM
Mar-26-2015 04:37 PM
Mar-26-2015 03:59 PM
