hotjag1's avatar
hotjag1
Mar 30, 2019
How important is a refer thermistor?
I have read on this forum that the thermistor is critical to proper refer temps because it controls the cooling cycle. Our refer starting running about 10 degrees warmer than usual(44 degrees) in 80 degree temps. I adjusted the thermistor up and down at different intervals and the temps didn't change.
After adjusting the thermistor several time the plastic clip broke off, so I just laid the broken piece with the attached wire on the shelf. After a couple of hours the refer temp went down to 37 degrees and this morning it was at 33 degrees. I changed the setting on the front of the refer down one notch and the refer stayed at about 37 degrees. So why do I need to replace the thermistor if it seems to maintain a decent temp using the front control button? It is a double door Dometic.
