TC_Z
Nov 05, 2022Explorer
MountainAir05 wrote:
Seems like we replied to this a few weeks back. Take it you did not want to pull inside. Did you check just below the roof line where the antenna is installed. As stated almost always a connector there so only a few feet to add.
Not a lot to pull on the roof. Point A to B, glue, tape and drill a new hole and seal.
This might help you. Ideal
Correct, I had a post a few weeks back. Wasn't a matter of not wanting too, I can't. The Winnebago motor home has solid styrofoam in the roof. There is no air space. They cut out channels for the wiring harness and air vents prior to being laminated together. This makes it impossible to pull any wiring thru after lamination.
I did check just below the roof line at the antenna mount. I did not find any coax connection. I also checked with Winn Tech support. They said Winn runs a continuous line from the antenna head, down the crank up lift arm, into the roof, down the 20 ft length of roof to the electrical closet. So there is no connection under the antenna mount. The closest connection is in the electrical closet. Thanks though....
38,709 PostsLatest Activity: Mar 09, 2025
