lacofdfireman's avatar
Feb 18, 2014
How to dump fresh water on my Class A
So we bought a "Used" new to us Georgetown 351DS Bunk model and am wondering how to drain the Fresh Water. In my last RV it had a Handle just like the Black and Gray tanks that you pull and it would just dump it all. You could pull it and drive home and it would be empty by the time you get home. On this particular Motorhome all I see is a low point drain. When I open it a tiny bit of water will trickle out and then stop. Our fresh tank is full so I know it can't be this. Unless you have to run the pump in conjuction with the low point drain being open. If you do that water sprays out. Just not sure if this is the way to do it or not? I scooted around underneath on a creeper and couldn't find any other drains so I sure it has something to do with the low point drain. Just confused cause our last one you didn't have to run the water pump to drain it. I don't want to mess something up like if the pump is on and no water is coming out do I have to shut it off immediately so I don't harm the pump? Any help appreciated..
