JackMS's avatar
JackMS
How to pressure check propane system
Trying to pressure check my propane system after doing some repairs. Thought I would just blow air pressure into my auxiliary connection. The regulator is leaking as fast as I can put the air in-almost. Is this normal when putting pressure backward into the regulator or do I have a regulator problem?
The original problem was that the solenoid valve was not working and tank was full. Don’t use propane much so after a few years I decided to fix it and found tank empty, so there is a leak somewhere. I fixed the valve but want to check system before putting propane back in. Propane makes me a little nervous so I am a little overly cautious maybe. Just not fond of big booms
