Fastfreddy14
Aug 30, 2019Explorer
Inverter/converter vs stand-alone units: lots of questions
I have a 2008 Winnebago sightseer 35J. I’m looking to upgrade the parallax 7400 converter/charger to a better charger for my two 6V deep cycle batteries. I’m doing some research I was also thinking of upgrading my 300 watt Dimensions unlimited power inverter win-12/300.
I’d be looking in the 1000watt range at most just to run the tv and DVD and other small 120v stuff.
I know I’ll have to upgrade the wiring from the batteries to the inverter if I go to a bigger inverter and I’m fine with that.
Do most inverter/chargers include a transfer switch?
Is it better to get two standalone units or should I get an inverter/charger to replace both?
Would I lose anything by going to a single unit instead of two?
What is the best brand to go with? Is there an inverter/charger that has a 4phase charging system like the progressive dynamic units?
Has anyone done this?
I can easily locate the inverter since it is under my sink but I can’t find the converter/charger. Does anyone know where it would be?
