AikenRacer's avatar
AikenRacer
Leak on Lippert Hydraulic system
I have a small leak on my hydraulic system. The unit consist of a tank, a pump block and the motor. Fluid is collecting at the base of the pump then dripping down. It appears that the fluid might be coming from where the tank bolts up to the pump face. I have tightened up the four bolts that hold the tank to the pump but the leak is still present. I talked to Lippert but all they said was I need to buy a whole new unit. Ain't gonna do that. None of the hoses or connections are leaking. I can't see anything on the pump itself leaking. I am sure I am not the first person to experience a leak like this. If any of you have any comments or have had similar leaks please give me some advice. Thanks!
  • What I would do is remove the reservoir and clean out the O ring area and get dry. Then use Axle grease or a heavy grease to lube the o ring and track and reinstall and make sure the reservoir is supported. This may be enough to keep the DEXRON from seeping out. Doug
  • Thanks, I figured there had to be a gasket or oring between the tank and pump block but could not get anyone at Lippert to tell me. All they said was I needed to buy a whole new assembly. I just don't have thousands to throw away like that.
  • Second Chance wrote:
    There should not be any pressure at the tank/pump interface so, unless the tank is overfilled, fluid should not leak there. I would look carefully at the pump itself and any attached manifolds. I had a leak in our Lippert system - but it was from the manifold that controls the slides.
    Rob
    When you have a O ring that fails, it does NOT take pressure for the reservoir to leak. Doug
  • There should not be any pressure at the tank/pump interface so, unless the tank is overfilled, fluid should not leak there. I would look carefully at the pump itself and any attached manifolds. I had a leak in our Lippert system - but it was from the manifold that controls the slides.
    Rob
