Couser's avatar
Couser
Leveler pump
Does anyone know where the fuse is on a 1999 Tropical class A Motorhome to operate the hydraulic pump for the levelers.When I bypass the pump it will work.I figure there is a fuse blown somewhere.The pump is made by HWH.
  • Thank you Sir!I have no books with this camper I do thank you for your response.I will look for this.Thank You again.
  • There is a small resettable lever circuit breaker in the passenger side forward storage compartment kind of behind the green PCB board in that compartment.
    I used to have one, took forever to find it. If you have a owners manual, an illustration is in it.
