othertonka
Sep 05, 2014Explorer
Fleetwood usually uses power gear levelers. The best thing to do is go back to square one. Start the engine, Move the shift lever to PARK. Make sure you put the emergency brake on fully. Turn the levelers switch to ON. push front leveler switch and listen for leveler motor to run. Give that a try, could be that you missed a step somewhere in your procedure. Report back with results and we can go from there.
