rencinas's avatar
rencinas
Michelin tire replacement for 235/80 22.5R
Need to replace my Michelin 235/80 22.5R tires that came with my Allegro Buss. Latest price I got was 480 per tire. I think Michelin is over priced, yet I cannot find a competitor's replacement time of that size. Surely there must be someone out there besides Michelin that produces a replacement tire. Can anyone give me advice on the subject?
  • I remember seeing this question before...for what it's worth, here's a quote of a sensible-sounding answer from an old thread:
    Hooligan wrote:
    Posted By: hooligan on 05/28/10 06:04pm
    Mike: The 235/80R22.5 is a Michelin size. The equivalent by other mfgr is 245/75R22.5, same specs, diameter and loading. Load Range G
    My MH came with the XRV 235/80R22.5 and I went to the Goodyear G670RV, 275/70R22.5. Basically 1/2 inch bigger diameter, an inch wider tread and 2000 lbs more load capacity. (Load range H)
    Going to a larger tire, check Dual spacing and clearance in the wheel well.....
    Each tire manufacturer website will have the specs for their tires. Size, diameter, rpm per mile, load, width and spacing requirements to compare. (the 255/70 is slightly smaller diameter but is available in Load range H for highly load rating)
    ..choices.....
