โJan-16-2017 02:30 PM
โJan-18-2017 06:40 AM
โJan-18-2017 06:05 AM
โJan-18-2017 03:59 AM
DSDP Don wrote:
"sid-orlando".....An RV is not like a house where you can cut a hole and frame in a new window. If you cut into the wall of an RV you could seriously damage the structural integrity of that wall, especially if there is steel substructure there.
โJan-17-2017 07:44 PM
โJan-17-2017 09:23 AM
โJan-17-2017 09:20 AM
โJan-17-2017 08:56 AM
โJan-17-2017 08:35 AM
Mr.Mark wrote:
Jharrel, you are correct in that it does cost more but the base starting price for the Winnebago Vista is $97,525 and the Vista LX is $114,848 (a little over a $17K difference).
The OP said the TV was not an important item.
MM.
โJan-17-2017 08:00 AM
โJan-17-2017 07:44 AM
Mr.Mark wrote:
Mr. Sid,
For the money that you would be spending to make changes to the Vista 31BE, you could move up to the Vista LX 35B or Sunstar LX 35B (looks to be the same unit both with bunks) that has a big window by the dinette. The plus is it has a bath and a half.
Mr.Mark wrote:
On unit that you are reviewing (31BE), be careful if it has the Schwintek slide on the that huge full wall slide. Many threads here on RV.net on Schwintek.
โJan-17-2017 07:31 AM
crasster wrote:
Change the TV location, or even get a different size tv to fit somewhere else. I'm with you OP, nothing should block windows while traveling.
โJan-17-2017 06:56 AM
โJan-17-2017 06:52 AM
โJan-16-2017 08:10 PM
