rockhillmanor wrote:
If you do decide to tow a car look into the tow bars that include the braking system.
Plenty of forum members here use that type and can give you advice on that type of braking system.
Those types eliminate the need to buy a Brake Buddy which has to be inserted ""on the floor"" of the toad and hooked up to the brake and up against the seat, then adjusted, etc. Put in when you leave and then taken out when you want to use it. All while bending over.
I bought the Brake Buddy and it is a strain on the back if you have a very small low to the ground car.
I had a Chevy Tracker and I literally had to get down on my knees to insert the braking system. Which was painful for my knees and back.
If I had do overs I would buy the all in one braking tow bar.
There is no such thing as a tow bar that includes a braking system. Not sure what you are referring to.
