bob_b
Sep 04, 2013Explorer
Nevercold now very cold, east fix!
Long story short, bought an '06 Bus from La Mesa Rv in Mesa, Az. They promised to fix refer which would not cool below about 44 degrees no mater the setting. They tried, replaced the thermister, still no luck. They suggested I find a repair facility here in Oregon so I contacted a local mobile rv repair service, Chuck's Mobile Repair. Chuck was GOOD! He removed the circuit board, hot wired the cooling coils directly to 110ac and noted the whole refrigerator became a freezer. It was 24 degrees inside! This proved the cooling unit was not the problem. He then checked the circuit board and determined it was good also. The "fix" came after he looked up at the coils visible from the outside looking up through the access panel. He first used duct tape for a temporary check and we noted the temps inside went right to 34 degrees and stayed there for two days. He came back and replaced the tape with a small piece of sheet metal which is visible in the photo. Problem solved! He said the clearance was too great between the coils and the wood surround which allowed the air flow to bypass the coils entirely.
I have searched the forums here and at Tiffin and noted many folks unhappy with their Nocold four door lack of cooling. Some posters have even replaced their cooling units and still had problems. I'm betting this "fix" will repair many of the problem refrigerators. Bob
