k_jensen6's avatar
k_jensen6
Mar 02, 2015
Norcold 1200 LRIM
We have a 2001 HR Imperial DP. With the infamous Norcold 1200 in it. The recall was done.
Yesterday I noticed that the frig temp was slowly climbing.
I did some research, and unplugged the thermister over night. This morning frig was back to temp.
Thought I would check out the backside to see if there was anything else that might be obvious to cause this.
I removed the outside panel, looked around, didn't see anything. Then stuck my hand in there to see if something might have come loose.
The compressor (?) and coils are extremely hot to the touch. Is this normal? Is this because I disconnected the thermister? (I've taken a picture of this part, but don't know how to post it).
I haven't had the thermister re plugged in for long as of right now, so not sure if that might be what have done it.
But, it is quite hot, and am now concerned about a fire, overheating, burning out.
I've left the outside panel off for an hour, hadn't cooled down.
We are in the Keys, it is about 80 outside.
Running 30 amp. Frig is not overpacked.
