David0725's avatar
David0725
May 28, 2017
Onan generator
My brother is camping in his 2000 Class A gasser with a 5500. Onan generator he says it runs fine at idle but when he turns on the A/C it shuts off. He does have a full tank of gas. Any recommendations what it might be or what he should do?
  • Does it just die or does it sputter and die? Mine would sputter and die after a bit of missing and surging. It required a serious adjustment to the carb and new fuel filters and new spark plug.
    If it just dies, then I have no suggestions.
  • I think he just had all new fuel lines put in.. I know he has a 30apm set up but not sure if he has a switch the goes from land to genny?
  • My first guess is fuel starvation, he may want to replace the inline fuel filter going to the generator and see if that helps.
  • What other electrical loads are being used? Electric on on water heater? Microwave, coffee pot, etc. try shutting things down and try turning it back on.
