Overdrive lockout on ford e450
Redram99
Does anyone know if it’s possible to wire in a switch to lockout overdrive?
It would be great to be able to drop the tranny to drive in advance of a hill. I feel it would put off shifting to 3rd significantly.
This would make cruise control much more useable.
I have already installed five stars tuning which made a night and day difference.
Thanks.
19 REPLIES 19
Tvov
What year is the vehicle? With my 2008 F250, the tow/haul does not "lock out" overdrive, it delays shifting into it until you are cruising on flat roads. My truck has the 5 speed torque-shift transmission.
_________________________________________________________
2021 F150 2.7
2004 21' Forest River Surveyor
rockhillmanor
jerseyjim wrote:
Just push the button located at the end of the gearshift selector.
Little light comes on says "off".(Overdrive is now turned off)
Why you would want to do this permanently...I don't understand. On a flat road, take advantage of the lower RPMs, especially in CruseControl.
Yup! that's what the tow mode button is for! :B
Push a button and overdrive is off.
Mich_F
If you're driving on a lot of hills, I'd suggest turning off the cruise control and engaging the tow/haul feature, if not already in use. I believe it's a good idea, to always have tow/haul turned on.
2014 Itasca Spirit 31K Class C
2016 Mazda CX5 on Acme tow dolly- 4 trips ~ 5,800 mi
Now 2017 RWD F150 with a drive shaft disconnect
JaxDad
Keep in mind that once the TX drops out of overdrive the converter lockup releases also, when that happens the slippage creates a lot of heat fast.
Unless you have a TX fluid temperature gauge you could very quickly get above the critical temperature of 225 deg. F.
Bad things happen very quickly after that.
jerseyjim
Just push the button located at the end of the gearshift selector. Little light comes on says "off".(Overdrive is now turned off)
