Parking brake will not disengage
woods_kitt
I have a 2002 Fleetwood Fiesta. This morning we were attempting to leave for a trip for spring break and discovered that the parking brake will not turn off. We have checked fuses, fluid levels, and wiring. Not sure what else to do. Brake light slightly dims (but doesnt go out) when P-brake button is pushed. There is no sound at all of it attempting to disengage. I topped off brake fluid (which was still pretty full), changed out all fuses, and checked all of my wiring.
If anyone has some advice for us, we would welcome it!
Thank you!
7 REPLIES 7
olfarmer
Yes if it is a Work Horse P32 chassis, it has auto park. Check the oil in the Plastic oil tank in the steel box that is usually mounted underneath the coach on the passenger side behind the transmission. There is a place you can see the level and a black plastic cap to where you fill it. If it is out of oil fill it with automatic transmission oil. I carry a spare rotten green switch as they can cause trouble. If you want more information google "old used bear" he specializes in rebuilding auto park units and has a lot of info about them. Good Luck with your problem!
Ed & Ruby & the 2 cats
2001 Winnebago Brave 30W
7.4 gas Work Horse Chassis
99 Jeep Grand Cherokee
dieterrv
Check all fuses first.
If P-chassis do not pull the pin .!!!!! There is still pressure on the cable probsbly. You need 2- 19mm open wrenches and slowly lossen tension on the cable and drum brake will release. Of course chock all tires before doing anything. the lock nuts are on the cable at the front of the steel box enclosing the P-Brake mech. There are several posts about the system on IRV2 site. Likely the rotten green switch as is has become known as. All parts are avaiable at a commerical hydralic supply.
Gjac
If it is the workhorse chassis which is what it sounds like from your post, there is a pressure switch inside the steel box. When you put the shift lever from park to any gear you should hear the pump come on. Do you hear the pump? If so, it is probably the pressure switch. The older ones were green, but I understand the newer versions are brown. If you can confirm you have the workhorse chassis with the auto park system, and the pump comes on you will get more help.
RLS7201
OP said "P-brake button". That would indicate Workhorse P32 chassis with DRUM BRAKE on the end of the transmission.
So the hydraulic release pressure is not over coming the brake apply spring.
To the OP. Chock a tire, then go under your coach and remove the cable pin, near the drum, that applies the E brake. That will allow you to drive to a service center. You will NOT have park or an E brake, so have you co-pilot chock the tires when you stop.
Richard
95 Bounder 32H F53 460
2013 CRV Toad
2 Segways in Toad
First brake job
1941 Hudson
Horsedoc
Crank it, put in into gear and hit the release. Could be the "frozen" the brakes and rotor together with a layer of rust from sitting for a while without being used. Very light attempt to move forward and back will likely break it free if that is the problem.
horsedoc
2008 Damon Essence
2013 Jeep Sahara Unlimited
Blue Ox tow
ArchHoagland
How long has it been since you've driven it anywhere?
Does you engine start and run OK?
And, as enblethen asked...Ford or Chevrolet.
2004 Monaco La Palma 36DBD
Workhorse W22 8.1 Gas Allison 1000, 7.1 mpg
2000 LEXUS RX300 FWD 22MPG 4020 LBS
US Gear Brakes
enblethen
What chassis, Ford or Chev?
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
