Sort By
- Executive45Explorer IIIFor those looking at upgrade and sticker price on the solar charger, look at the other costs too. My coach windowed at $600,000 with those similar upgrade charges. i.e. $632 for a $300 RV Sanicon, $432 for $110 exterior shades, $1411 for a $600 washer/dryer - the list goes on. That's why they knock off 35% window sticker so easily....Dennis
- Mile_HighExplorerThat was an order sheet at MSRP. Hopefully the original owner paid nowhere near that. Typically factory options are a fair value when you look at the discounted price.
- timmacExplorer
dougrainer wrote:
Ocean Mist wrote:
dougrainer wrote:
timmac wrote:
$1343.00 for the 3M protective mask on front that will turn yellow long before the paint goes bad than a $1000 to remove and touch up damage paint from removing.
I would rather deal with a few rock chips before the 3M mask ordeal.
Well if your buying used I guess that's not your cost but the 1st owner sure had to pay that.
The RV is 10 years old. What do you see wrong with the front Cap??????????????????? Doug
I have looked by I'm not sure what your referring about? little help...
Tinmac is claiming your unit has the 3M front cap clear mask and that because of that your front Cap PAINT is ruined and the 3M mask is defective, NOT true. I have worked on scores of Motorhomes with both 3M and other clear masks. As long as the paint was allowed to cure correctly before the mask is installed, there are no real problems with clear mask. IF the paint is not allowed to cure(dry) for a few weeks, then clear mask installation can cause problems. But I do agree, paint chips and bugs are not a big deal. Why pay for that clear mask? Doug
I was referring to the cost of the 3M and the issues some have had with the 3M and cost to remove and sometimes damage to the paint as well, the motorhome in pics looks good, maybe its been removed or soon it will start to turn yellow or get mold under the 3M that many have complained has happened. Fact..
In the invoice the OPer has posted shows the 3M was added and cost over $1300.00.
I suggest if buying new to avoid the 3M cost and possible problem down the road and use the money for something else. Ocean Mist wrote:
Tinmac is claiming your unit has the 3M front cap clear mask and that because of that your front Cap PAINT is ruined and the 3M mask is defective, NOT true. I have worked on scores of Motorhomes with both 3M and other clear masks. As long as the paint was allowed to cure correctly before the mask is installed, there are no real problems with clear mask. IF the paint is not allowed to cure(dry) for a few weeks, then clear mask installation can cause problems. But I do agree, paint chips and bugs are not a big deal. Why pay for that clear mask? Doug- Ocean_MistExplorer
I have looked by I'm not sure what your referring about? little help... - Mile_HighExplorer
Mr.Mark wrote:
Thanks Mark, that would be a nice feature.Mile High wrote:
Boy that is a nice coach! What is the See vision with monitor option?
Mile High, that was one of my favorite items on our '08 Dynasty. There was a monitor on the dash (Aladdin system) that you could pick a camera to view. You could toggle between either side camera, the rear camera or the inside camera that was located where you would have a rear view camera.
If Mom and Dad were in the bedroom, they could turn on the screen in the bedroom and toggle through the camera's outside or watch to see what the kids were doing in the living area.
We have a similar system in the Liberty where I can look around the coach from the inside through the camera's. We don't have an interior camera in this one.
Safe travels,
Mark - mike_brezExplorerI can't see to good but how do you know from the pictures that the 3m film is still on. It could have been removed and repainted.
The RV is 10 years old. What do you see wrong with the front Cap??????????????????? Doug- Mr_Mark1Explorer
Safe travels,
Mark - Mile_HighExplorerBoy that is a nice coach! What is the See vision with monitor option?
About Motorhome Group
38,716 PostsLatest Activity: Apr 26, 2025
