ricelake922's avatar
ricelake922
Pump for leveling jacks won't turn on
Hello. I have a 1996 Monaco Dynasty. I have a RVA model JII leveling system. The green light goes on to state the system is ready but when I try to extract or retract the pump does not turn on. The pump has enough fluid. The air brakes are at the max PSI but i do try to extract the front jack but the pump does not go on.Can you please assist on how I can get the pump to go on. Thank you in advance m
  • Hello. Thank you for your assistance. What did work was taking a rubber mallet and tapping the pump which worked as the pump started up.
    fischer wrote:
    1 in park and either acc or ign position
    2 battery needs to be 8 volts
    3 try pushing the auto level. , sometimes sw makes bad contacts
    go to rvajacks.com they have a troubleshooting section
    I believe a green light says system inop pushing sw should get you a flashing green light
    and the pump has a delay before starting
    Get out the Multimeter and check the connections.
    More times than not a pull and replug will cure.
    BOL,
  • 1 in park and either acc or ign position
