Coach Cleats wrote:
My first request refered to the front CHF. The most resent was for the rear CHF.Thank you for your helpful advice.
Answer is the same - no jacks. I personally wouldn't get under an RV with the jacks down, understanding that the tires should save you if they let go, but the jacks might lift it up enough for you to get your hand or anything else somewhere that if the jacks were to let loose, you could loose whatever is stuck in that gap. No thanks and no need. Never mind the fact that the jacks will drop the wheels and make the job harder not easier. There's enough space and if fairly level, just reverse the z brackets and done. KISS method on this one.
